Vieux 01/05/2011, 20h39   #1
nexelec
Par défaut Liste couple serrage Agusta F4
Bonjour à tous ,
Pour ceux ne possédant pas la revue technique voici les couples de serrage des éléments de nos F4.
Désolé c'est en Anglais !!!
MV AGUSTA F4 S/F4 S 1 + 1
TORQUE VALUES – CYCLE PARTS, EXCLUDING ENGINE
FRAME
Description Type Torque [N•m] Notes
Front fixing screw – engine M12x1,25 55/60
Guide screw M6x1 TEF 8/10 Loctite 242
Upper fixing screw – engine M12x1,25 55/60
Lower fixing screw – engine M12x1,25 55/60
Plate/frame fixing screw M12x1,25 TEF55/60
Plate/frame lower fixing screw M8x1,25 TCEIF24/28
Plate/frame upper fixing screw M8x1,25 TCEIF 24/28
Fixing screw – plate/footrest supportM8x1,25 TCEIF 24/28
Sump/plate fixing screw M8x1,25 TCEIF 23/25 Loctite 242
Side stand nut M8 Gally 24/28
Nut for lock M22x1,5 In contact + 30°
HANDLEBARS AND CONTROLS
Clamp internal screw M6x1 TCEIF 8/10
Clamp external screw M6x1 TCEIF 8/10
Clip-on handlebar screw M6x1 TCEIF 8/10
Fixing screw – brake pump/clip-on handlebar M6x1 TCEIF 5/6
Accelerator screw M6x1 TCEIF 6/8
Eccentric screw – pedal M6x1 TCEIF 8/10
Pedal pin screw M8x1, 25 23/25
Fixing screw – pump support M6x1 TEF 8/10
Fixing screw – pump support/engine M8x1,25 TCEIF 23/25
Fixing screw – pump support/engine M6x1 TEF 8/10
Gear change pedal screw M6x1 TCEIF 8/10
Special screw – hydraulic unions M10x1,25 16/18
Screw for hydraulic union with discharge M10x1,25 16/18
Clip-on handlebar counterweight screw M6x1 TCEI 2
FRONT SUSPENSION
Screw – fork/wheel attachment M10x1.25 20/22
Fixing screw – base/inserts M6x1 TCEIF 8/9
Phasing screw – steering head M12x1 18/20
Steering lock screw M5x0.8 TCEIF 5/7 Loctite 242
Fixing screw – head/inserts M8x1.25 TCEIF 16/18
Fixing screw – frame head/steering sleeve M8x1.25 TCEIF 22/24
Terminal screw M6x1 4/6
Fixing screw – connecting rod/shock absorber support M6x1 8/10 Loctite 270
Fixing screw – connecting rod/steering head M6x1 8/10 Loctite 270
Steering shock absorber support screw M6x1 TCEIF 4 N
FRONT SUSPENSION
Steering shock absorber/frame screw M6x1 TCEIF 8/10
Steering bearing screw ring M35x1 In contact + 10°
Frame head steering screw ring M76x1.25 95/100 With grease also
on the conical part
REAR SUSPENSION
Description Tipe Torque [N•m] Notes
Rear brake pincer support peg M12x1.25 30/35 Loctite 242
Upper guide screw M6x1 2
Upper chain cover screw M6x1 4/5
Lower attachment screw M10x1.25 TCEIF 40/44 Loctite 242
Fork spindle screw M15x1.25 TEF 70/75
Lower connecting rod screw M10x1.25 40/44
Upper connecting rod screw M10x1.25 TCEIF 40/44
Compensator screw M10x1.25 50/55
Lower fixing screw – shock absorber M10x1.25 TCEIF 40/44
Upper fixing screw – shock absorber M10x1.25 TCEIF 40/44
Rear wheel hub screw M12x1.25 28/32
FAIRING AND MUDGUARDS
Front mudguard spoiler screw M6x1 TCEIF 2
Tail unit support fixing screw M6x1 TEF 6/7
Sub-frame/anti-heat wall fixing screw M6x1 TEF 2/3
Conduit/Headlight support screw M6x1 TEF 6/8
Reflector nut M4 GALLY In contact + 90°
Tail rotation fork screw M5 x 0,8 TSPEI 3
ELECTRICAL SYSTEM
Side stand micro-switch screw M5x0.8 TCEIF 5/7
Cover/air intake screw M6x1 6/8
Horn screw M6x1 TEF 2/3
Electrical wiring plate screw M6x1 TEF 2/3
Headlight support screw M7x1 12/14
Number plate light nut M5x0,8 GALLY In contact + 90°
Rear stoplight fixing screw M6 x 1 TCEIF 5
FUEL FEED
Rapid engagement terminal 1/4" NPT 3 Loctite 577
Tank – lower flange screw M6x1 8/10
WHEELS AND BRAKES
Left nut – rear wheel spindle M48x1.5 200/220
Right nut – rear wheel spindle M50x1.5 left 220/240
WHEELS AND BRAKES
Front wheel spindle screw ring M35x1 40/44
Crown wheel nut M10x1.25 poligonale 45/50 Without grease
Rear brake disc special nut M7x1 18/20 Loctite 270
Rear brake pincer screw M8x1.25 TCEIF 23/26
Front brake disc screw M8x1.25 TCEIF 23/25 Loctite 242
Upper front brake pincer/attachment screwM10x1.25 TCEIF 38/42
Lower front brake pincer/attachment screw M10x1.25 TCEIF 38/42
Pin screw M8x1 20/22 Loctite 270
EXHAUST SYSTEM
Fixing braking nut – exhaust pipes/cylinder head M8x1.25 GALLY 16/18
INSTRUMENTATION
Instrument panel screw M5x0.8 4/5
SEAT
Seat screw and rear anti-vibration M5x0.8 TBEI 2
NUTS AND SCREWS NOT INDICATED IN THE TABLE:
Generic nuts and screws M5x0.8 5/7
Generic nuts and screws M6x1 8/10
Generic nuts and screws M8x1.25 22/24
Generic nuts and screws M10x1.5 34/37
Generic nuts and screws M12x1.75 52/57
Type =dimensions de la vis
torque= couple
In contact + 90°=serrer jusqu'au contact et faire serrer d'1/4 de tour
Voila Si questions n'hesitez pas
Vieux 01/05/2011, 22h24   #2
nexelec
Pour ceux qui ne savent pas lire l'anglais
Rien de tel que des photos
https://picasaweb.google.com/1130771...Kjen6b00OmFew#
Vieux 06/05/2011, 20h47   #3
nexelec
J'ai même pas eu un merci ...
Ca vous interesse peut etre pas ???
couple, liste, serrage
Fuseau horaire GMT +2. Il est actuellement 07h07.
